header bolt replacement
Old Jul 9, 2005 | 01:56 AM
slpss9723's Avatar
Default header bolt replacement
Is it safe to replace stock header bolts with stage 8s without replacing your gasket or getting leaks, if you do it one bolt at a time and torque to specs??? Just curious......
Old Jul 9, 2005 | 11:08 AM
bolton98TA's Avatar
you will be fine, im thinking about doing the same just to be on tha safe side
Old Jul 9, 2005 | 11:32 AM
blkZ28spt's Avatar
You'll be fine. Heck, most people install headers and use the stock bolts and gasket.
Old Jul 9, 2005 | 12:42 PM
1FST99Z's Avatar
yeah I used the stock bolts and gaskets and havent had a problem yet
Old Jul 9, 2005 | 04:51 PM
bolton98TA's Avatar
same here
Old Jul 9, 2005 | 05:00 PM
davered00ss's Avatar
Moderator
I reused my stock gaskets when I did my Kooks headers and no leaks after almost 2 years.
