electric fan mod ?
Old Jul 9, 2005 | 04:21 PM
Blank's Avatar
Default electric fan mod ?
Has anyone modded their fans to stay on after the car is turned off?If so how did u do it
Old Jul 10, 2005 | 10:59 AM
LS1FIRE's Avatar
I used the slp manual fan switch to do this. You also can control the speed level as well.
Old Jul 10, 2005 | 11:04 AM
blkZ28spt's Avatar
As he said, a manual fan switch allows this. I have one. Word of advice in case you get one...NEVER use it to run the low speed fan unless you are SURE that you will remember the fan is one or hear it when you get out. An LED indicator would be very nice. You can't miss hearing the high speed fan, but the low speed is quiet enough to accidentally leave it on overnight and kill the battery. Multiple times.
