Question on high idle after mods
Bill
I don't think that that would cause such an ungodly high idle, tho. You mentioned that the MAP (-?) sensor in the back wasn't secure? That might do it. If you had a scan tool, I'd say take a look at what the O2 sensors are reading. If it's Lean, then of course you have a vaccuum leak. A leak severe enough, when installing a new manifold, would cause such a high idle. Spray some non flamable brakeclean around the mating surfaces of the manifold. If the idle changes, then you've found the leak.
It's an old trick, I'm almost positive that it's brake clean..... Look into the trottle cable thing too. If that's the case, then cheap and easy first. Right?
When you turn the AC on the computer recognises a load on the engine and it uses the IAC motor to bump the idle up a tad to compensate for the load. The load on the motor is what is lowering your idle. when you take that load away the idle returns to where it was. Idle Control, it keeps the idle where it should be.
The TP voltage is supposed to change with throttle plate angle differances. It tells the computer what the throttle plate itself is doing. The voltage does not change w/ idle, unless the computer changes the blade angle w/ the IAC motor.
