Car has no power and shakes
Old Jul 12, 2005 | 07:46 PM
Doc's Avatar
Doc
Burnt / Broken O2 sensor wires. One or both sensors (Internally)could just be done too.
Old Jul 13, 2005 | 01:54 AM
01black's Avatar
HOLY crap...teh same exact thing just happened to my ride....i took it back to teh tech and they said it was a cracked spark plug. Not enough to see but a slight crack. Is the SES light flashing?
Old Jul 13, 2005 | 02:00 AM
Z-286speed's Avatar
I had that problem with a new cam install, and all it was, was the engine sensor fuse. After that was fixed, no problems at all.
Old Jul 13, 2005 | 03:51 PM
WhitePheonix's Avatar
Where the hell is the engine sensor fuse at? SES on
Old Jul 13, 2005 | 03:58 PM
01black's Avatar
Go to an autozone ask for the obd 2 scanner and pull the code...symptoms sound JUST like mine did...is it backfiring?
Old Jul 13, 2005 | 04:08 PM
Little bit of backfiring, sounds like **** when I did drive it, at idle sound awesome, when I was driving it it almost sounded like a machine gun, can't drive it, kept stalling out the other day on my way to work
Old Jul 14, 2005 | 09:22 AM
01black's Avatar
You have GOT to be mis-firing...mine sounded the SAME exact way. Swtich ALL the plugs!!!
Old Jul 14, 2005 | 10:26 AM
MW2 Performance's Avatar
Another posibility on the plug side, is somewere along the lines of them removing the plug and re-installing them on installation, the droped a plug and closed the gap or something, and believe me, with lt1's anything is bound to happen on the pasenger side, I just changed my first set of LS1 plugs and took less than an hour total, all I can say about that is there is no comparisson between an ls1 and an lt1 on plugs
Good Luck bro, hope you get it sorted out. Go to the shop and watch if they will let, you, and get a glimps at those plugs!
Old Jul 16, 2005 | 10:51 AM
Well got the car back from MORE, runs much better. Had two cracked spark plugs and a cracked coolent sensor. But now Im throwing codes, PO171 two times, and PO174 two times. Each one says Engine running lean both Bank 1 and Bank 2. Will the computer adjust to this or will I need a dyno tune.
Old Jul 16, 2005 | 12:32 PM
Allright since I got out of the gym the codes have vanished. But Ive notice a strong smell of gas and exhaust everytime I drive the car. Is this a characteristic of the ORY and no cats. I swear I get a headache from it and reak of gas once Im done driving. Do you think I have a leak somewhere?
Old Jul 16, 2005 | 06:56 PM
Im thinking of having my ORY welded. It is currently leaking. What do you guys think about this?
Old Jul 17, 2005 | 12:49 AM
  #32
70T/A400's Avatar
Get rid of the leak through welding or seal it with high-temp silicone. Just make sure you don't get any on the 02 sensors as it can mess them up.
Old Jul 17, 2005 | 02:44 AM
  #33
JustAnIlluzion's Avatar
Where are these sensors located at?
they are under the intake manifold. wheres your winter beater when u need it?
Old Jul 17, 2005 | 06:31 AM
  #34
GuitsBoy's Avatar
I dont think this warning is explicit enough. Keep all RTV's away from o2 sensors as the fumes alone can kill them. First, use only "o2 sensor safe" high temp RTV. While even this stuff will kill o2 sensors eventually, its helps slow down the effects of silicone poisining. Secondly, use the RTV only downstream of the o2 sensors. Thirdly, apply the RTV only to the outside of a small leak, dont put it on the inside of your clamps or slip fit pipes when assembling, as when you tighten the clamps, it will gush out of both directions, and when the RTV gushes out into the inside of the pipe, the exhaust heat will release the silicon fumes. Even if it's downstream, after you shut the car off, the heat will still release silicon fumes which now can find their way upstream to the o2 sensors since there's no flow preventing this.
-T
Old Jul 17, 2005 | 12:17 PM
  #35
Thank You very much for all your help!!! I just bought some band clamps as opposed to the hangers, I will see how those work.
Old Jul 17, 2005 | 03:16 PM
  #36
Zymosis's Avatar
Im kind of confused why you posted question after question on here and then when people gave their opinion you said I dont have time to screw with it I'm taking it in. Should have just taken it in from the get go.
Glad you got it working though.
As for reaking of gas, thats the lovely smell of exhaust is from your lack of cats.
