ls1howto.com coolant plug torque spec= DONT USE!!!
Old Jul 12, 2005 | 03:43 PM
redtail2426's Avatar
Default ls1howto.com coolant plug torque spec= DONT USE!!!
I was swapping my ls1 intake for an ls6 and looked up all the torque specs to use my new inch pound torque wrench.On ls1howto.com is says the coolant plugs(i am assuming the plugs used during the swap)should be torqued to 15 ft lbs.This is wrong that converts to 180 inch pounds and the bolt will break off in the head at 150inlbs.The correct spec is 106 in lbs for the plugs and the front collant crossover.luckily i heard the bolt snap and was able to back it out before it completely broke.let me know if a collant plug is something else im not thinking of.
Old Jul 12, 2005 | 03:46 PM
777's Avatar
777
You should probably try and pm JMX as well so he can change it on ls1howto.com
shouldaboughttheZ's Avatar
did you send them an email or something to give them a heads up?
Old Jul 17, 2005 | 11:30 AM
WILWAXU's Avatar
LMAO! I've probably do 6-7 H/C cam installs using Jon's site. Of course I've never been **** enough to use a torque wrench on those bolts.
Like said above, shoot him an email so he can get that fixed.
Old Jul 17, 2005 | 02:20 PM
DONAIMIAN's Avatar
e-mail him so he can take care of it, I never really use a TQ wrench on anthing thats a bolt on, besides a pully.
jmX's Avatar
jmX
Hi there, sorry for your mishap, but I'm curious where you found reference to those crossover pipe plugs being 15lb/ft? In the intake install doc itself I dont list any torque spec, and on my torque spec page the "Cylinder Head Coolant Plug - 15 lb/ft" listed is the large plug that goes into the side of the head, in place of a coolant temp sensor. Maybe I should clarify that that plug is NOT the same as the coolant crossover pipe plug....I was just listing stuff just like GM does, right out of the manual.
In the torque list, what you wanted was "Coolant air bleed pipe bolts and studs - 106lb/in".
Glad you got the broken bolt back out!
alrighty i will do that and email him.Brand new torque wrench,i had to use it.love new tools.
