Broke a Bolt
Old Jul 15, 2005 | 05:14 PM
02BlackOnBlackSS's Avatar
Default Broke a Bolt
I was changing my oil for the first time and I took off the wrong bolt, and when I was putting it back, it snapped off. I am wondering how important it is. The bolt is located right next to the oil filter and it is a 10 mm bolt. The bolt is pretty long. Can anybody help?
Old Jul 15, 2005 | 06:08 PM
conan's Avatar
Is it one of the bolts that goes through the oil pan and up into the timing cover?
Old Jul 15, 2005 | 06:11 PM
Yeah I am pretty sure it is. It is a long bolt.
Old Jul 15, 2005 | 06:12 PM
Bluehawk27's Avatar
yeah it is, as long as you dont have oil leaks, you might be alright. But you will have to deal with it if you ever have to drop your pan.
Old Jul 15, 2005 | 06:15 PM
conan's Avatar
Did it snap because of cross threading of from over tighting? If its over tightened usuly the head snaps off and the the shank isn't that tight a pair of vice grips will take care of it. Is it leaking oil?
Old Jul 15, 2005 | 06:37 PM
shawn's SS's Avatar
What do your fenders look like now?
sorry I couldn't resist
Brains's Avatar
Sounds more like one of the bolts in the oil temp sender fitting (not used on an F-body, its not drilled/tapped). You'll want to remove the other bolt, remove the block and remove the broken portion of the bolt - then replace the bolt. If you don't chances are it'll leak oil. That fitting is under full oil pressure, so you don't want to risk a leak there -- could be very dangerous since it'd spray right on the hot exhaust.
Old Jul 15, 2005 | 06:50 PM
ss rally red's Avatar
OK no one else has asked so I will Besides the DRAIN plug and the oil filter why were you removing anything else..........
Old Jul 15, 2005 | 06:58 PM
Overtightening, The shank is way in there it snapped at the bottom where it is threaded.
Old Jul 15, 2005 | 07:00 PM
No oil is leaking from the bolt, It would just spray straight down if something would happen. I will check for leaks though later on. I'll try that if it starts leaking.
Old Jul 15, 2005 | 07:01 PM
It was the first time I changed the oil myself on the car, it is fairly new. I was trying bolts and that one looked like it could be it, but it wasnt. I went to replace it and it broke.
Old Jul 15, 2005 | 07:12 PM
If it helps, there is a bolt just like it on the other side of the transmission.
Old Jul 15, 2005 | 07:36 PM
conan's Avatar
http://www.organ1zedcha0s.com/phpBB2....php?pic_id=47
Put you mouse on the bottom right corner of the picture you can blow it up, Look to the right of where the oil filter goes the one that goes straight up in to the rear cover is that it?
Old Jul 15, 2005 | 08:52 PM
JustAnIlluzion's Avatar
dont know how much space u have to play with, but i have drilled broken bolts then removed then with a EZ out.
Old Jul 15, 2005 | 09:15 PM
You can't see the bolt from the picture. It goes straight up from the bottom. It is about 2-3 cm from the oil filter
