TSP ORY Install help!!
Old Jul 16, 2005 | 03:49 PM
akZ28's Avatar
Default TSP ORY Install help!!
I have pacesetters installed and am trying to install the tsp ory but the tubes dont seem to be big enough and we cant get em to fit together. the car has magnaflow on it.
Old Jul 16, 2005 | 04:35 PM
bolton98TA's Avatar
oh it is a bitch, but give it time and a lot of work and it will go togeather. use some kind of lub to help ya out too.
Old Jul 16, 2005 | 05:14 PM
S1LV3R's Avatar
Once getting the pipes together a chain/strap wrench would be helpful in orienting the pipe so that it clears on the driver's side floorboard and tranny crossmember.
Old Jul 16, 2005 | 06:57 PM
akZ28's Avatar
Finally got that peice of **** together. Man that thing sux
Old Jul 16, 2005 | 06:58 PM
WhitePheonix's Avatar
It fits, I have the exact same set up as yours. Did it last friday. Only problem is that my Y pipe leaks, thinking about having it welded next week.
Old Jul 16, 2005 | 07:26 PM
skywalkrNCSU's Avatar
SSU, come over and relax
what a pos
i wouldnt reccomend that thing to anyone. we finally got the thing on but it hangs so low that it scraps on everything. i dont know if i got a bad one or not but the pieces were not the right angle or length. i know everyone says it is tough to put on and its just like that and everything but this was obviously not made right.
well it looks like time to fab up some true duals and trash that sorry y-pipe
Old Jul 16, 2005 | 07:31 PM
It does hang low as hell, has anyone else had theirs welded?
Old Jul 16, 2005 | 08:05 PM
i couldnt even go over the smallest speed bump i have ever seen without it feeling like my whole exhaust was gonna rip off
 Michael S. Palmer
oh and i couldnt get the small crossmember back on
what did everyone else do about this???
Old Jul 16, 2005 | 08:18 PM
bolton98TA's Avatar
its ok to leave your cross member off. thats what most people do. but yours hangs low? mine tucks up ferry nicely. you can rotate the pipe on the drivers side to adjust how low it hangs. i had more of a problem of mine hitting the bottom of the slore under hard acceleration.
Old Jul 16, 2005 | 08:27 PM
S1LV3R's Avatar
Mine is as close as possible and still hangs low. Guys at Fastech trimmed part of the tranny crossmember to keep it from hitting the floor board. I also painted mine flat black to make it less obvious. Of course if it is banging the floor board and scraping on everything it's hard to be less obvious!
Old Jul 16, 2005 | 08:28 PM
yeah we cant adjust it at all
the way we got it on was pretty much the only possible way we could get the pipes to connect
Old Jul 16, 2005 | 11:26 PM
stangkiller's Avatar
on my tsp ory the "y" thats welded together; the hole cut to weld them together is not as big as the other pipe so there will be a lot of turbulence and not free flowing, seems no better than the stock y pipe. i am gonna have try to reach inside there and use a metal file to file it down some, seems like a lost cause though.
Old Jul 17, 2005 | 12:20 PM
Ditto on the speed bumps, now my driving consist of constantly monitoring speed bumps and dips in the road, the crossmember did not find its way back on my car.
Old Jul 17, 2005 | 12:40 PM
so do you think if i get it all welded together by an exhaust shop it will be better or should i just save my money and get true duals fabbed up?
Old Jul 17, 2005 | 12:49 PM
Im going to go to the exhaust shop and have it welded if my band clamps dont help with the leaks. I would hate to have it welded unless I have to because I think it would be harder to get on and off as one piece.
Old Jul 17, 2005 | 12:53 PM
yeah i agree but i dont think im ever gonna take it off....at least not for a long time and then it would be because i would scrap it so i could just cut it up
Old Jul 17, 2005 | 01:00 PM
What are the emission test like down here in NC, do they run the sniffer? Do you think you would pass with duals?
Old Jul 17, 2005 | 01:25 PM
i have no idea what emissions are like in nc i get my car inspected in texas (its registered in san antonio and i go to school in raleigh). im not really worried about emissions i just want a good sounding, quiet at low rpm, no clearence issues exhaust
Old Jul 17, 2005 | 01:27 PM
**** if you dont have to worry about it in Texas go with true duals.
