Valve Cover Temps
Old Jul 24, 2005 | 09:50 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Default Valve Cover Temps
How hot do you think the temp of valve covers would get? Would they get 170 degrees or hotter?
Keith
Old Jul 24, 2005 | 11:11 AM
parbreak's Avatar
My guess would be at least as hot as the oil temp. Are you thinking about painting them?
Bryan
parbreak
Old Jul 24, 2005 | 07:39 PM
ls1290's Avatar
Yes, the paint I would liek to use says it is good up to 170 degrees.
Keith
Old Jul 24, 2005 | 07:49 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I would go higher than that.... Figure the oil will be close to 200-210 degrees if not higher since it's coming straight from the pan.
Old Jul 24, 2005 | 08:39 PM
SiL3NtXWS6's Avatar
Use hi-temp caliper paint. I have used 2 different spray paints and the caliper paint works the best, without a doubt.
Old Jul 25, 2005 | 08:05 PM
WILWAXU's Avatar
Powdercoating works great. Like said above, high temp paint should do the trick.
