Volant Cold Air Induction Question
. Stuck a few pieces a few inches apart all around. It acctually rests on it right before it latches in. I have to give it a little extra push. That and it has made a contact mark on the underside from were the rubber meets the hood. I think since a volant is an upgrade option for a z29, they took it's design into account when they made the mold for the hood.Maybe keeping the center section from bending will solve my sealing issues.
Thanks
Dave
What is the largest diameter=
Small diameter on the end=
Outer diameter of the tubing they slide on to=
The filter length=
I'm also wondering about the hoods it fits. Will it clear on a regular TA hood or is it only for the Ram Air?
FloridaZ, could you show those pictures again? They are not showing up. Thanks.
Thanks
Dave
Thanks
Dave
The tube I think you are refering to is the fresh air inlet for the air injection pump that runs when you first crank up the engine. It's not real important. Your car should have that tube, you can just add a small filter and tuck it out of the way.
Well with my FIPK, I believe that where the tube used to run from the stock lid to there, the tube is no longer and the filter is just clamped right on top. But with the volant kit it looks like that filter is inside so does that mean that the tube needs to run from that filter to that air inlet thingy that is towards the front of the car on the drivers side? Thanks
Dave
Does that help you understand?
