Installing my march pulley???
Old Jul 31, 2005 | 09:47 AM
Tranzaman00's Avatar
Default Installing my march pulley???
Not another pulley thread!!! I was just wanting to know what tools worked the best when installing the march underdrive pulley. I absolutely do not want to beat it on. I am also having a little trouble finding a tq. wrench that goes up to 240#'s. So far all I have is an extra gm bolt and the pulley puller.
Do you use the longer arp bolt to just seat it or do you actually leave that one in? I have also searched and seen the all thread rod method.
Old Jul 31, 2005 | 11:35 AM
iamsickofitall's Avatar
try to find a longer bolt - i tried everything from heating the pulley to torching just the inside of the pulley to beating it - the longer bolt makes all the difference - and don't attempt the autozone tool...it didn't come close to being able to work for me
Old Jul 31, 2005 | 02:24 PM
So just use the longer bolt to seat it, and then take it out and re torque with a new factory bolt?
Old Jul 31, 2005 | 04:33 PM
shawn's SS's Avatar
You won't be able to seat it all the way with a longer bolt. Get it as far on with the longer bolt as you can without damaging the crank and then use your original bolt to finish seating it and then install the new bolt.
Old Jul 31, 2005 | 04:35 PM
I never realized it was this much of a PITA! I just don't want to mess anything up or put to much stress on the internal threads, Thanks for the help.
Old Jul 31, 2005 | 04:38 PM
shawn's SS's Avatar
Seems that most people like using threaded rod to seat the pulley though which makes sence because you won't be putting as much stress on the crank threads.
Old Jul 31, 2005 | 04:40 PM
I guess thats what I'll use. thanks
Old Jul 31, 2005 | 04:42 PM
shawn's SS's Avatar
P.S. the chrysler pulley puller rented from autozone worked sweet when removing my pulley.
Old Jul 31, 2005 | 04:44 PM
Which pulley did you go with March,ASP.........
Old Jul 31, 2005 | 04:46 PM
shawn's SS's Avatar
stock had to take it off when installing the hotcam. I would like to get a march pulley someday.
Old Jul 31, 2005 | 04:48 PM
