cooling question...need help!!
Old Aug 1, 2005 | 06:05 PM
1971ssLS1's Avatar
Default cooling question...need help!!
i have a ls1 conversion in my car, with a 160 t-stat, aluiminum radiator, and dual electric fans. There is one sensor that is located on the front drivers side cyl head that reads the water temp for the ecu. i put a sending unit for an autometer water temp guage on the rear on the passenger side head. While idling, the guage for the ecu reads a consistant 195-196 while i had a scanner pluged in. at the same time, the guage kept rising and rising to like 220-230. as is starg to drive though, the guage eventually drops back downb to about 165. just trying to see if there is an explaination for this? thanks for any help!
Old Aug 1, 2005 | 06:45 PM
TAQuickness's Avatar
just a guess, but you probably need a little more air flow than the fans can provide at idle.
