Electic cutout - how to do wiring?
Old Aug 7, 2005 | 12:55 AM
The PAT WS6's Avatar
Default Electic cutout
im gettin ready to do an qtp electric cutout on my car and wondering if anyone has pictures of exactly how they got the wires from under there car to inside and where did you mount the toggle switch and how u wired everything? any info would be great thanks
Old Aug 7, 2005 | 08:02 AM
ls14jay's Avatar
I don't have pictures but can explain what I did.My cutout location is under the rear passenger seat.At that location there is a rubber gromet in the floorboard.I ran the wires up through it and under the carpet.Removing the rear seat was nesessary.It was a bit of a pain getting my arm under the carpet but not terrible.Continue it under the carpet to the center console.I mounted the switch in the ashtray(non smoker). Very convenient location for the switch.There is enough cable to make it to the dash if desired.Actually quite simple.I had everything pre-wired just leaving the connection hanging below car and took it to the exhaust shop.Weld it in, attach the wire and done.
Old Aug 7, 2005 | 08:52 AM
Skyranger's Avatar
Exclamation Found this
I am looking to do the same, found this (slight variation on Jay's routing, but essentially the same)
http://www.stealthram.com/qtpcutout.html
Great shot of ash tray switch
https://ls1tech.com/forums/showthrea...=cutout+wiring
Old Aug 7, 2005 | 11:44 AM
so the qtp elec. cutout comes with everything you need in there package right?
Old Aug 7, 2005 | 11:55 AM
Skyranger's Avatar
Not sure, in the same boat as you, interested in the answer though
Old Aug 7, 2005 | 11:59 AM
ya well i went to their website and it says it comes with everyhitng but i see people making their own wiring harness and etc. with their electric cutout? so i was just planning on gettin the package from qtp that says it comes with the toggle switch cutout out and wires for like 189.99 and hopin that will do the trick
Old Aug 7, 2005 | 12:20 PM
Skyranger's Avatar
Thumbs up
Unless I hear something to the contrary, that was what I was/am gonna do (what kind of English am I usin' ??? )
Old Aug 7, 2005 | 02:22 PM
mrr23's Avatar
you're welcome
 Michael S. Palmer
Old Aug 7, 2005 | 03:17 PM
SiL3NtXWS6's Avatar
It comes with everything you need including detailed instructions. The instructions tell you how to mount the switch and where to put the wiring. You are going to need to remove the bucket from the passenger side rear seat. Cut a slit in the black floorboard plug, and pull the wire through it. Use a coathanger and run the wire under the carpet , into the console. Going to tap into the pink TCS wire and the black cigarrette wire for power and ground. Easy.
Old Aug 7, 2005 | 05:42 PM
ls14jay's Avatar
Yeah comes with everything needed.It can be done in about an hour or so.Mine came with a lighted toggle switch so make sure you hook it to a power source when key is on, or the LED could drain battery.
Jay
Old Aug 7, 2005 | 06:26 PM
spy2520's Avatar
I plan on running mine to the TCS switch by the fog light switch since i dont have TCS. Doesnt seem too hard.
Old Aug 7, 2005 | 06:36 PM
USMARINE1108's Avatar
Exactly what I did, but I didn't take the seat out.
Old Aug 7, 2005 | 07:12 PM
2001NBMZ28's Avatar
It'll be easy, I've installed a QTP and McCord - just post if you run into any problems.
Old Aug 7, 2005 | 09:06 PM
Skyranger's Avatar
Thumbs up
you're welcome
mrr23,
Thanks for taking the time to post that initially, will greatly help my "instructionally impaired" self by providing idiot proof pictures. This is a cool web forum
Earl
