Bassani TD's
but in a proper fix, you should use 3 inch to 2.5 inch reducers, and clamp them on, and you will have to cut the drives side pipe and i think modify the passenger side pipe a little....
needless to say i am going to have to go to a shop and have them fix the shitty work on htere... but it is doable
https://ls1tech.com/forums/showthrea...hlight=bassani
Is the catalyst material in this actually a metal of some sort? Does it do anything for emissions, or just smooth out the sound?
