Nice Plug for lid breather hole
http://nick.vettextc.net/AIR%20Removal/Inside001.jpg
As you can see it's barely noticeable from a distance, is almost flush with the lid.Sticks out aprox 3/32 of an inch. It's press-fit and gives a very tight seal, partly due to the material, forming around the contour of the lid's radiused top edge.
Best of all I got it free as a sample from this company:
www.caplugs.com
It's part number BPF-1 1/8-6. I think you can order these online but may have to buy a large quantity. You might be able to request a free sample like I did. The company I work for has bought products from them in the past so I had no problem getting them. If anyone is interested and has a problem ordering let me know and I can help you out.
So any of you guys planning to remove your AIR from your 00-02 car don't waste money buying a new 98-99 lid like I had planned.
anyway just thought I'd share.
I should mention when you go to install the plug don't try just forcing it in. I did this at first and had no luck. I placed the plug near the edge of the workbench center it over the hole then positioned the lid on the edge of the workbench and pressed the lid down onto the plug, went in alot easier that way.
