Can stock cats be welded onto an ORY?
Old Aug 17, 2005 | 01:30 PM
hurley711's Avatar
Default Can stock cats be welded onto an ORY?
I have 2 brand new stock cats so I figured I'd save the extra $$$ it costs for a catted Y and have them welded onto an ORY. Is that possible? Will the stockers fit?
Old Aug 17, 2005 | 01:34 PM
v8maro's Avatar
possible? yes. practical? no. the ORY is probably 3" and the stock cats are 2.5" i believe. Buy some high-flow cats and save u the trouble of reducing and enlarging pipe sizes.
Old Aug 17, 2005 | 02:09 PM
greatskiiiier's Avatar
if you dont live in CA dont bother with cats
Old Aug 17, 2005 | 02:33 PM
LoudmouthLT1's Avatar
More states then CA require emissions...Anyways, you can buy high flow cats that are 3 inches in/out so it'll be easier to deal with and will flow better.
Old Aug 17, 2005 | 02:57 PM
hurley711's Avatar
Yeah I'm gonna go with Texas Speed. Coated Pacesetters and a TSP catted Y only run $700 over there, can't beat that.
Old Aug 17, 2005 | 03:52 PM
d james's Avatar
you can make the holes big enough to install on the Y, the only downfall is the stock cats don't flow as well as high flow cats, but if money is tight, I say why not. By the way I've welded in stock cats, and it wasn't to hard, but I do prefere the aftermarket ones. Check out soundcats on Ebay they are 40 bucks and flow just as good as the best aftermarket performance ones.
Old Aug 17, 2005 | 04:19 PM
hurley711's Avatar
Gonna go with ORY and maybe I will weld cats in later. Thanks james
