testing coils...
Old Aug 18, 2005 | 11:21 AM
hourang's Avatar
Default testing coils...
i wanted to test my coils to make sure im getting enough voltage. i had a couple tech guys tell me that you can go to napa or somewhere and buy an inline volt reader or something to test the voltage and that there only like $5. anyone hear of this or know what there talking about?
Old Aug 18, 2005 | 06:07 PM
slowpoke96z28's Avatar
http://buy1.snapon.com/catalog/item....re&dir=catalog
or the test light style
or the screw style with graduations marked in kilovolts
they all go on the secondary side and if you can change plug wires, you can use these tools.
Old Aug 19, 2005 | 07:53 AM
hourang's Avatar
Originally Posted by slowpoke96z28
...or the screw style with graduations marked in kilovolts...
this is what im talking about, i know im getting spark, just need to make sure its enough.
Old Aug 19, 2005 | 09:02 AM
spy2520's Avatar
pull the plug, then connect the plug wire back to the plug then put your tongue on the two sark plug electrodes. If you die its getting enough. Get someone you dont like alot to do to it. Perfect suicide. "Guy was changing my plugs and killed himself." J/K
Old Aug 19, 2005 | 10:26 AM
hourang's Avatar
lol....seriously i need to test this as 2 different tech guys both suggested my coils could be bad is why my nitrous doesnt work right, they tested everything else.
Old Aug 20, 2005 | 01:37 AM
WILWAXU's Avatar
Easy way to "test" the coils is to swap them to different positions and see if the problem follows.
BTW: never seen one go bad, plus there are LS1 making ~1000+ hp on the stock ones
Old Aug 20, 2005 | 10:10 AM
hourang's Avatar
there is nothing to swap, i havent the slightest clue where one could be bad. i get a mult cyclinder misfire even after i got the car tuned but it could still just be the cam i dont know.
Old Aug 20, 2005 | 10:13 AM
SS2win's Avatar
cant help you on the tester but whats the spark plug gap? have you tried tightening it up by 5 or 10 thousandths?
 Michael S. Palmer
Old Aug 20, 2005 | 10:41 AM
hourang's Avatar
no i havent, the gap is set at .038 and is only a 75 shot right now.
