Steering Shaft re-installation
Old Sep 3, 2005 | 04:43 PM
angst911's Avatar
Exclamation Steering Shaft re-installation
Ok, had to remove the steering shaft to get my drivers side header removed so it could be repaired. I put the header back in (kooks 1 7/8) w/o a problem. But now for the life of me I can't get the steering shaft back on. Please, give me the idiots step by step guide!
Old Sep 4, 2005 | 01:47 PM
Xtnct00WS6's Avatar
I don't remember which bolt I put back in first...the top or bottom. But I do remember that an extension and a swivel came in very handy.
Old Sep 4, 2005 | 04:32 PM
zerotosixzero's Avatar
i just did this yesterday. i jacked the car up, and i put the top of the shaft onh first. then i put the bottom on. you can easily get at the bottom of the shaft from underneath the car, the top however required the use of an extension
Old Sep 4, 2005 | 05:09 PM
USMARINE1108's Avatar
I started it in the top, then had someone guide it in the bottom (from under the car) while I tapped it in with a long screwdriver from the top.
