Motor mount install
Old Sep 4, 2005 | 10:24 PM
Mr. Luos's Avatar
Default Motor mount install
Like the idiot I am, I didn't make a mental note of the tabs on the mounts.
When installing the mounts back onto the block, do those tabs face down or up???
Looks like either mount will fit either side, but I need to know which way that tab faces.
Thanks in advance!!!!
Old Sep 5, 2005 | 10:18 AM
Mr. Luos's Avatar
Anyone have any pics maybe?
Old Sep 5, 2005 | 11:19 AM
shouldaboughttheZ's Avatar
Which mounts do you have. I have pics of my energy suspension ones.
Old Sep 5, 2005 | 11:44 AM
Mr. Luos's Avatar
I am using the stock clamshells with Prothane inserts.
There is a little tab on the mounts. Trying to figure out which they face when mounted onto the block. Up or down?
Old Sep 5, 2005 | 12:48 PM
DWillTA's Avatar
The Tabs face up. I did this install last weekend. Good Luck.
Also, the three rivet side of the clamshell faces up.
Dave
Old Sep 5, 2005 | 06:54 PM
INTENESS's Avatar
Yes just did mine they face up you might have to cut them off to work
Old Sep 5, 2005 | 09:40 PM
I had to grind off the bottom 2 tabs.
The poly mount should only fit in the clamshell one way.
Old Sep 5, 2005 | 11:20 PM
Mr. Luos's Avatar
Right. But the clamshell with fit two different ways onto the block.
Tab would be either up or down.
Thanks for the help guys!!!
 Michael S. Palmer
Old Sep 7, 2005 | 12:00 PM
This is how it should sit on the block. I had to grind off the bottom 2 tabs to get the bolts in.
