passenger poly motor mount worth it?
Old Sep 10, 2005 | 05:16 PM
Red99TA's Avatar
Default passenger poly motor mount worth it?
I installed the driver's side about 8 months ago to help w/ y-pipe banging but still got some until I wedged a rubber piece b/w the pipe and under the car. My question is whether or not it's worth it to put the passenger side in and will it help with banging at all? I have a week off so plenty of time to do it although the drivers side was a biotch to do. I also have HPTuners coming this week so I'll be playing around with that too. Any suggestions?
Old Sep 10, 2005 | 06:45 PM
DOUBT IT's Avatar
Some people say that it's not worth it. It was in my case however, because when I pulled my pass. side stock mount, it was cracked the whole way through, and wasn't dampening a damn thing.
I say you have it, why not go ahead and throw it on...
FWIW, my motor is so still now it doesn't even appear to be running.
Old Sep 11, 2005 | 06:58 AM
TAQuickness's Avatar
do it. just as much fun as the driver side, but worth it.
Old Sep 11, 2005 | 08:58 PM
Hagarr's Avatar
Heck I just did my passenger side and it solved 95% of my y-pipe problem. I'll do the drivers side soon.
Yes...do it. Take off the starter and you'll be good to go.
B
Old Sep 11, 2005 | 11:48 PM
00PewterSS's Avatar
No idea because I did them both at the same time. I removed the header, starter, A/C compressor and bracket. I can tell you the engine doesn't seem to move at all.
I didn't remove the pedestal as I found the bolts were rediculously tight even after I broke them loose. I didn't want to snap one off so I decided to not remove the pedestal.
Brian
