O2 sensor wires
Old Sep 11, 2005 | 12:55 AM
chupr0kabra's Avatar
Default O2 sensor wires
Does anyone have a picture or two of how you routed the O2 sensor wires on the driver's side with LT headers? I burned up the wires on mine because they touched one of the header tubes (oops) and that caused the sensor to go out. I got a new sensor (little buggers are expensive!) and extended it, then routed as much as I could behind the heat shield. I can't find anything to attach a cable tie to, though, to keep it from touching the headers again.
Suggestions/pics? Mine are Pacesetter headers, btw.
Thanks,
-Mike
Old Sep 11, 2005 | 12:57 AM
JMBLOWNWS6's Avatar
I dont have pics but I routed it right by the block. There was a threaded hole there and I just used a c bracket to support it. Also heat wrapped it.
