Problem w/ intake swap
Old Sep 11, 2005 | 02:38 AM
Cop Car's Avatar
Default Problem w/ intake swap
so i removed the intake, and broke the oil pressure sending unit... so i got one off of a 2001 camaro (mines a 2000) i seem to have "0" oil pressure in the gauges on my dash, it worked fine in the other car... anyone have this happen to them when swapping intakes? is my 2001 sending unit not playing with the 2000 computer? or did i smash a wire or break something do you think... i tried to get my hand back there but i cant feel it at all..btw swaping the intakes on f bodies sucks bigtime
Old Sep 11, 2005 | 04:12 PM
s346k's Avatar
anyone? ttt
Old Sep 11, 2005 | 04:57 PM
SSTYCOON's Avatar
01-00 Oil sending units may have the same part #, Thats why you have to call your local Dealership and see what the parts numbers are.
If you're not get any reading on your gauge, then something is hooked or connected. you just gotta eliminate the simple things first, maybe buy a knew sending unit?
Old Sep 11, 2005 | 05:07 PM
Red99TA's Avatar
I broke mine too but bought a new one. You're right about it sucking to do the intake swap. I thought when they weren't connected or if they were broke then it would max out the gauge instead of reading zero?
Old Sep 11, 2005 | 05:12 PM
SSTYCOON's Avatar
If the sending unit is broken off, it'll read excessively high oil pressure
Old Sep 11, 2005 | 06:15 PM
felton316's Avatar
Actually, you have it backwards. If the sending unit is broken, it will read zero. If the sensor is left unplugged, it will read max.
Old Sep 11, 2005 | 07:20 PM
Cop Car's Avatar
ok... so how do i replace a broken oil pressure sending unit without removing the intake again?
Old Sep 11, 2005 | 07:24 PM
s346k's Avatar
pay someone to do it for you. i know a guy here local that would gladly remove your ls6 intake, replace your sending unit, and install an intake with less use for cheap. pm me.
 Michael S. Palmer
Old Sep 11, 2005 | 11:10 PM
marine02ss's Avatar
As a GM tech simply get yourself oil pressure univ socket with patience remove it less than 5 minute swap trust me easy
Old Sep 12, 2005 | 12:35 AM
Cop Car's Avatar
how to i reach back there with the intake still on the car?
btw you need to post all the time in tech !
Old Sep 12, 2005 | 02:12 AM
BrianC98Z28's Avatar
howd you break the sensor? Removing the old one of puttin on the new one? If you were removing did you forget to lift the booster line over it? I think thats what breaks it isnt it? If I remember right.
Old Sep 12, 2005 | 07:31 AM
99Ws6TransAm's Avatar
Your not gonna be able to fix it with the intake on...I did the same thing..theres just no room. And it sits lower then the inake valley...theres a little recess there and its in the very back. Gonna have to take that intake off again..
Old Sep 12, 2005 | 01:15 PM
Cop Car's Avatar
i actualy broke it both times apparently...
Old Sep 12, 2005 | 08:41 PM
SSTYCOON's Avatar
oh,
Thanks
