lt install 02 procedures?
Old Sep 12, 2005 | 09:03 PM
02ZZ28's Avatar
Default lt install 02 procedures?
Ok im pretty sure i am capable of doing the install but im a little unclear of what to do with the 02 sensore. My car has 33,000 miles on it but since it is a good time to change the 02's should i? And if so should i use the rear 02's from a vett. Im also gonna change the plugs but undecided on which ones, and at what gap to put them. ( im all stock except for intake and LT's)
Thanks for any help
Old Sep 13, 2005 | 09:51 AM
01formula6's Avatar
You can just re-use your front 02's and get a set of extensions for about $35 so they will reach once you install the LT's. If you want to get the rear 02's from a vette you can also do that and you will not need extensions, however those will run you about $160. As far as plugs the TR55's seem to be a popular choice, thats what I used. I checked to make sure each plug was at .055, and used that gap.
Old Sep 13, 2005 | 09:55 AM
02ZZ28's Avatar
Thank you for that information
Old Sep 13, 2005 | 10:48 AM
01formula6's Avatar
No problem.
Old Sep 13, 2005 | 12:57 PM
02ZZ28's Avatar
ok i ordered my headers y pipe plugs and wires today from byunspeed.com. An I have one last question. should i start my car after the install of the headers without the 02 sensors so i can let the coating inside the headers burn out, then after a little bit of the car runnning then put the 02 sensors in?
Old Sep 13, 2005 | 09:00 PM
Lithium's Avatar
SSU's Drunk Typing Whore
No, you have to leave the front o2 sensors in. Just screw them in and start it up with open headers if you want.
