getting ready to install headers few last minute questions
2.When installing the headers should i put the new plugs in before i install the headers, or wait till the header is in before installing the plugs. 3. what is the procedure for disconnecting the battery i read so many different ways i think i confused myself. Those are basically all i need to know but if anyone has any first hand experience with 2002 lt's from pacesetter with emmissions id like ot hear from you. any tips or tricks to make the install go easier would really help.
thanks Joe
For my car I could not get the headers in with plugs in, so you should probably just put the plugs in after the headers are bolted up.
For disconnecting the batter just take the cable off the NEGATIVE terminal. It takes a 5/16 wrench.
When installing the new plugs, use anti-seeze compund and don't over tighten them. Sometimes it is easier to get #8 by removing the starter.
Headers are tricky. Do you have additional 02 cables for your front set? What are you doing about the rear 02s? Are you using 02 simulators?
Your car will run very rich after the install because the front 02s are much further down in the exhaust stream Vs. stock. Do you plan to get it tuned to lean it out after the LT install?
Before you tighten any header bolts make sure you have started ALL the bolts into the heads. This is easeist if someone helps you by supporting the header while you start each bolt. Don't screw this up or you will be removing the heads.
What year car? Do you have reducer plates made with the holes drilled for the AIR system? Your AIR check valves will flutter and burn out without them. Make them from tin or copper sheets that you can buy at Depo. I think it is a 5/16 hole.
Your PVC system will now suck a bunch more oil into the TB intake manifold. DO you have a large catch can ready for installation to stop this?
I would buy new plugs and a GOOD set of wires too. You need a new set of exhaust gaskets; right?
Leave the plugs in when you take the manifolds off, prevents dirt/crap getting in, leave them in while installing the headers, unless the get in the way, you can use rags or paper towels to plug the holes if it concerns you
Make sure you have the car is pretty high to install them, good jack, and stands, and maybe some wood (4x4s) if you need extra height
There is a PVC vacume hose connected to your throttle body. It sucks air from the valve covers into the intake.... when you get headers the pressures change and oil is usually sucked out of your valve covers too... Install a BIG oil catch can and or ls6 valley cover to stop the oil.
Your AIR system has flutter valves. Depending on the year of the car, some headers have a flange (opening) that connects to the flutter valves..... these go nuts after a LT install..... the only fix is to block 90% of the pressure off by installing metal gaskets over the flange. The gaskets have a single 5/16 hole drilled in them to reduce pressure and stop the flutter.
Most headers dont have bungs for the rear 02 sensors.... you need to buy 02 simulators (SIMMS) or have your car tuned and remove the rear 02 test.
Your car will run poorly after the LT install since it will be very rich, particularly at idle..... another issue casued by relocating the front 02s further back in the exhaust stream....
You better consider all these issues FIRST - before the install....
If you plan to go "cat-less" you will fail if the inspector looks under the car... since it is much noisier now with LTs, this is usually assured. Have a few $20s ready for him if there is a CAT challenge...
If you live in Commiefornia you will have to re-install the stock headers at least once a year at emmissions testing time...
They also drag on the pavement and get ripped off the car when you go over a speed bump....
chris
