How to Install Headers...
Old Sep 15, 2005 | 07:13 PM
SLIKWS6's Avatar
Default How to Install Headers...
are their any websites or places where I can find a write up on how to go about doing this?
Some people say you have to remove starter, some dont. Some say remove oil filter some dont. Some say you have to lift the engine up,some dont etc...
So any info would help out.
BTW, Im installing Pacesetters with the hookups and an ORY onto an 2002 Trans Am.
Thanks for your time guys.
Old Sep 15, 2005 | 07:58 PM
Lithium's Avatar
SSU's Drunk Typing Whore
https://ls1tech.com/forums/showthread.php?t=139142
Old Sep 15, 2005 | 08:03 PM
SLIKWS6's Avatar
hey thanks for your response man, ive read that thread so many times that I feel confident about the install, just these other little things like removing the starter and jacking up the engine and more. I guess I should of specified in my title.
Thanks though I appreciate it.
Old Sep 15, 2005 | 08:34 PM
Lithium's Avatar
oh, yeah no problem man.
When I installed my Pacesetters they just slid right in. I did not remove, cut, or modify anything. There were no problems getting them go in. Most people who install them have no problems as well. So you most likely will get them in without issues. If you do run into problems just post on here and we will help ya out
Old Sep 15, 2005 | 08:41 PM
mrhzk35404's Avatar
do you have to cut the k member?
Old Sep 15, 2005 | 08:59 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I agree. I did not cut , remove, spindle fold or mutilate anything to install the pacesetters except get the coil packs up out of the way. I did, however remove the pass side heat shield above the collector after the install.
Just make sure you have a decent floor jack if you don't have access to a lift, as you need to get the front up there higher than Rhino Ramps. I bought a Pro-Lift speed jack at Advance Auto for about $86, well worth it. (and a heavy ba$tard it is).
Lithium's Avatar
only if they hit while putting them in.
Old Sep 15, 2005 | 09:09 PM
Keenov's Avatar
I didn't do any cutting, pasting, moving, unbolting starters/alternators/concentrators/relaxators... I just unbolted the old exhaust and then slid the new headers right up in there without force. This was with the pacesetter headers done on two vehicles, '98 and '00, both went smooth.
 Michael S. Palmer
Old Sep 15, 2005 | 09:47 PM
TransLS1's Avatar
on my 98 i had to take off the steering shaft and a part of the oil filter off and it lifted right in there on the drivers side.
Old Sep 15, 2005 | 10:15 PM
bastien's Avatar
man, i have a set of pacesetter and ORY waiting for installation. You guys make me wanna get started instead of getting it done by a shop.
Old Sep 15, 2005 | 10:42 PM
Dino98T/A's Avatar
Do it yourself. Save that cash. Get a 10mm and 11mm ratchet wrench(will help a lot with the header bolt that is on the passenger side, next to the firewall). The steering shaft might get in your way, if it does take it off. My off road ypipe hit a little bit but a little grinding on the plate that goes over the catback-ypipe connection will cure this(might want to space the plate with some washers to get a little more clearnce). It took me about 9 hrs or so, but i took my time to make sure it was done right. Good luck.
Old Sep 16, 2005 | 10:13 AM
SLIKWS6's Avatar
Hey, again thanks alot for the answers guys, Im thinking theyll slide right in as well, so no
[QUOTE=Keenov] cutting, pasting, moving, unbolting starters/alternators/concentrators/relaxators... I just unbolted the old exhaust and then slid the new headers right up in there without force. \QUOTE]
Ive sat in the garage looking at the engine for hours, and from the looks of everything, Im hoping that everything will just slide in.
Old Sep 16, 2005 | 11:40 AM
01formula6's Avatar
I just installed my Pacesetters and ORY last weekend. It's a very straight forward install. My only advice would be to buy a 10mm ratcheting wrench with a flexible head. Besides that just take off the coil pack assemblies for extra clearance and get to work.
Old Sep 16, 2005 | 01:12 PM
bastien's Avatar
I don't have access to a lift and I only have one jack... I am getting ready to pay $400 for installations at a shop. At least I know they'll do a good job.
Old Sep 16, 2005 | 01:22 PM
GreekGator's Avatar
Go buy a jack and stands....youll spend less than 400, will do it urself, have the knowledge, and will still have the jack/stands afterwards. Its not a bad install at all.
Old Sep 16, 2005 | 02:43 PM
gwj's Avatar
gwj
That's your perogative. It cost me about $110 for a decent floor jack and heavy duty jack stands, a lot of sweat, a little blood, and my wife holding up the headers for me, but I'm glad I did it. If my old *** can do it, I'm sure most can. ...and I did it on the ground, no cement or asphalt. (gotta love that grass in your ear)
