motor mount problems
Old Sep 16, 2005 | 07:20 PM
00sscam's Avatar
Default motor mount problems
Ok can you help me figure this out.
Went and bought polyurtheane motor mounts
took the clam shell out and was suprised i drilled out the the 3 rivets on one side.the other side of the shell had solid mushroom head rivets.
now there is no way to clamp the shell together anymore i will have to get bolts and put bolts through the solid rivet side .
what is going on i though this was pop the rivets and swap it out .
I am worried the bolts i will have to put in is going to hold the clam together
Any ideas would be help full .
thanks chris
Old Sep 16, 2005 | 07:26 PM
Argon Z's Avatar
Picture would be very helpful
Old Sep 16, 2005 | 08:15 PM
00sscam's Avatar
Ya i know i forgot to take it with me i do not know what to do i do not want to take the other mount out and leave the moter suspended like that. I will try to take a shot of the other mount in the car tomorrow.
Old Sep 16, 2005 | 09:20 PM
00PewterSS's Avatar
What you are describing is normal.
The Prothane mounts come with the bolts. I don't know what kind you bought, but I would advise buying some bolts and nylon lock washers. You need 2 bolts on each side of the clam shell... in other words 4 bolts per mount. Make sure the head is on the engine side.
Brian
Old Sep 16, 2005 | 09:23 PM
TAQuickness's Avatar
I pressed mine together with a vice and welded it
Old Sep 17, 2005 | 12:37 AM
MM98's Avatar
I just did my driverside mount tonite & was wandering the exact same thing... I bought the energy mounts & they come with 2 stupid zip ties!!!! I ran outa time at work & will have to redo it again next week... 00 PewterSS, thanks for the info!
Mike
Old Sep 17, 2005 | 12:52 AM
Full-Force's Avatar
People need to stop buying those stupid energy suspension mounts. The Prothanes come with everything you need.
Old Sep 17, 2005 | 03:34 PM
00sscam's Avatar
Ok ran in to another problem i got it all together and went t6o go test fit the clam shell in the pedistil and ther is .5" of play side to side is this normal it can't be.
The original mount fit tight in the pedistal now i have .5" of play side to side that an't right
Part Number is # 3-1116 energy suspension black insert
has any one else had this problem
Old Sep 17, 2005 | 03:42 PM
OldeSkool's Avatar
