Ground Problem
Old Sep 20, 2005 | 07:18 AM
arctic2kss's Avatar
Default Ground Problem
Has anyone had a problem with any of the ground wires going to the engine after a header/cam install? Where on the block are all of the grounds located? About every other time I try to start my car is acts like the battery is dead, even though testing shows it isn't. This is also making the car not want to idle.
Old Sep 20, 2005 | 07:24 AM
Z'mnypit's Avatar
There is a ground on the pass side of the block, there is also one on the drivers side behind the altenator. & there are also a couple on the back of the drivers side head. Is it possible that the battery is bad? I know that you said it wasnt dead, but maybe its defective. When its idling whats the volt gauge on?
Old Sep 20, 2005 | 08:02 AM
arctic2kss's Avatar
The problem is intermittent and the battery shows good, that's why I believe it isn't the battery. I did remove the AIR system with the LT install, is it possible that one of the grounds on the drivers side head shares a bolt with the bracket holding the AIR system component back there. I never completely tightened the bolt back because it was such a pain to get to.
