Hooker Exhaust...need help
I've done four more since then, including two long-tube header installs, but these were done on my lift. Is a lift necessary? No. Does it make the job easier? Yes. I was fortunate enough to be able to install a 2-post lift in the shop I had built two years ago. This isn't something that fits everyone's budget, but if you ever find yourself financially able to put up a shop, go the extra mile and get a 2-post lift. You'll need a a 6" concrete floor, and a minimum ceiling height according to the lift you buy. Mine will work with a ceiling as low as 9'. 2-post lifts are surprisingly inexpensive...less than some hi-performance engine parts. I paid $1,600 for mine, and I don't know what I'd do without it.
