ls6 intake...direct bolt-on for 98???
Old Sep 21, 2005 | 08:07 AM
Raise's Avatar
Default ls6 intake...direct bolt-on for 98???
ok, heres the deal. i will be installing this on my 98 z28:
241 heads w/ 918s
224 cam
ls6 oil pump
and while i have everything off i might as well get an ls6 intake. do i need to do anything special or will it just bolt right on?? dont the ls6 intakes have a different pcv system underneath?? oh yeah, and im dumping the egr/air.
Old Sep 21, 2005 | 08:16 AM
thunderstruck's Avatar
underneath the intakes are coolant crossover lines for the heads. you can either get the ls6 coolant lines or notch out the underside of the ls6 intake where the old coolant lines run
Old Sep 21, 2005 | 10:55 AM
Keenov's Avatar
241 heads w/ 918s
224 cam
ls6 oil pump
So much for the third gen
You need a front coolant line from an '01-'02 LS1 and coolant plugs for the rear.
Old Sep 21, 2005 | 11:00 AM
MeentSS02's Avatar
Kleeborp the Moderator™
ls1howto.com is your friend
Old Sep 21, 2005 | 10:46 PM
Raise's Avatar
yeah, just couldnt stay away hey man u should come by someday soon and lemme check out your car. anything done to it yet?? anyway, gimme a call if u wanna come by 737-2881
