FAST intake install
Old Sep 23, 2005 | 08:58 PM
Mr. Luos's Avatar
Default FAST intake install
Motor is out of the car.
What am I missing here?? What holds down the MAP sensor at the back of the manifold??? Looks to me like it will just blow off.
Old Sep 23, 2005 | 09:29 PM
LawmanSS's Avatar
There is no provision on the FAST for the MAP sensor...most folks just glue it in with silicone (mine included)...others have fabricated a hold down bar using one of the rear bolts that holds the three pieces of the manifold together...
Old Sep 24, 2005 | 09:11 AM
Mr. Luos's Avatar
Well alright.
One would think that a $750+ intake would have port seals and little **** like the provisions for a sensor. Hope this thing is worth it, it looks like it is.
Old Sep 24, 2005 | 10:26 AM
bmfcamaro's Avatar
there is a pic of a hold down out there. i used it. the bolt that goes in the area of the map take out. then get a longer one. long enough to come just above map. then get a metal sleeve that can go around the bolt to hold the plates mentioned next up at the same level as the map. then fab up a plate that can bolt up to that longer bolt and cover up the map itself. then silicone and tighten. thats what i did and it worked perfectly. good luck.
Old Sep 24, 2005 | 10:43 AM
RedWS6 00's Avatar
I got the F.A.S.T intake and with the standard MAP it does seem very loose, I left it in place, and too not happy, got no brackets, I may take it out and silicone it, thanks for the idea. I dont think it will blow off, as its in a vacuum.
Old Sep 24, 2005 | 11:37 AM
FRDnemesis's Avatar
I'm not to happy that mine is loose either. I'm going to silicone it, and hopefully it will stay in place.
Jeff
Old Sep 24, 2005 | 12:29 PM
ls1 joe's Avatar
I drilled and tapped the hole that was originally designed for the stock map location for a 1/4 inch hose barb and ran a small hose from the barb to the map sensor and secured the hose with a couple of zip ties on the barbs. The hold down they send with the intake is kinda BS.
