Is this a for real LS6 intake
Old Sep 25, 2005 | 12:04 AM
neverstock's Avatar
Default Is this a for real LS6 intake
This is a completely new TPIS (Tuned Port Induction Specialties) 90mm oval throat LS6 intake manifold for 1997- 2004 C5 Corvette and Z06 models with the LS1, LS6 or LS2 engines.
It's specifically designed for the TPIS 90mm billet alum. oval throttle body for very high performance engine output. It makes an excellent upgrade choice for a head/cam package, supercharged, turbocharged and stroker engines to let them breath for BIG power
http://i21.ebayimg.com/02/i/04/f5/fb/93_1_b.JPG
http://i15.ebayimg.com/03/i/04/f6/c9/46_1_b.JPG
http://i2.ebayimg.com/03/i/04/fe/9e/c7_1_b.JPG
Old Sep 25, 2005 | 01:03 AM
N3V3RL8T's Avatar
For realz, No EGR hole behind the T/B= LS6
Old Sep 25, 2005 | 07:16 AM
XtinctZ28's Avatar
Rehab is for quitters...
Or a C5 manifold, I understand that the C5's from '97 on, never had EGR provisions. So just because there is no EGR hole, doesnt mean LS6 automatically. JMO
Old Sep 25, 2005 | 09:23 AM
Ole1830's Avatar
ask him to send you a pic of the bottom
Old Sep 25, 2005 | 09:32 AM
2mffZ28's Avatar
bottom must be flat. ls1 intake has a rib going down the center.
Old Sep 25, 2005 | 11:38 AM
Lithium's Avatar
SSU's Drunk Typing Whore
Yep the part number checks out. Its an LS6 manifold...all you had to do was search the part number.
Old Sep 25, 2005 | 07:10 PM
neverstock's Avatar
yea but it has a 90 mm tb opening
Old Sep 25, 2005 | 09:12 PM
RPO_Z06's Avatar
Note how it has a shine and darker look right behind the TB opening, I think they glued another TB opening on it and painted it to make it look factory.
 Michael S. Palmer
Old Sep 25, 2005 | 11:33 PM
Daredevil_TA's Avatar
like 2mffz28 said, best way to check is to look at the bottom to see if its flat
Old Sep 25, 2005 | 11:49 PM
ArcticZ28's Avatar
looks pretty jimmy-rigged.
Old Sep 26, 2005 | 12:23 AM
1hot91's Avatar
tpis doesn't make very good parts as it is.
Old Sep 26, 2005 | 08:58 AM
SSDriver's Avatar
sure looks like they epoxied on a 90mm opening and tryed to make it look factory. Only way to tell is to look on the underside and see if its flat. Eitherway I wouldn't want it, I'd rather spend the money and get the LSX. At least with that you know its quality and you can port if necessary.
-William
Old Sep 26, 2005 | 01:38 PM
Cop Car's Avatar
LS6 intake manifold (01-02) = 88894339 (formerly 88890524, 88890523, 12561184)
LS6 intake manifold (from Corvette Z06) = 12573572
yes it is an intake manifold off of a Z06 corvette.
and to the other guys...they said in their description specificly that they modified it for a 90mm throttle body. you cant just look at that one and say if it is an LS6 intake or not, you need to run the part#. Neverstock..that intake is modified for the 90mm TB, so you would probably have to get another TB if you got that, i dont know if thats what you want to do or not. if thats NOT what you want to do dont get that intake.
Old Sep 26, 2005 | 04:28 PM
Danny2tek's Avatar
Look at the TPIS website..........................>
Old Sep 26, 2005 | 05:30 PM
neverstock's Avatar
yes I think I will look for a different intake
Old Nov 22, 2005 | 03:51 PM
01SSDRVR's Avatar
Has anyone used this setup?
Old Nov 22, 2005 | 04:14 PM
Full-Force's Avatar
what are you smoking? TPIS makes very nice stuff and have been for a very long time.
Old Nov 23, 2005 | 09:35 AM
snketr's Avatar
I'd buy that over the fast 90 any day. TPIS has good stuff. Everything I've bought from them was awesome, esp the cams.
