PLEASE HELP! After LT Problems!
Old Sep 26, 2005 | 06:49 PM
TigerFan187's Avatar
Exclamation PLEASE HELP! After LT Problems!
OK sorry for this being so long but I feel it necessary. 3 weeks ago I did Pacesetter LT's(ceramic coated), removed cats, mandrel 2.5" all around,Magnaflow dual in/dual out single stainless muffler,and LT1 fans. I had a number of exhaust leaks but fixed them all and even put Nitrogen through the system to make sure. The next day I started to get a terribly rough idle-it would go to 3k and back down and repeat untill it ran for about 5 minutes then it would start to load up. When scanning I wasnt getting consistent o2 readings so I replaced both front 02's(obviously the rears are gone and turned off) and they were both totally clogged so it was needed. Well since I got the new o2's(stock ones) it has gotten worse. It feels like when your driving with 7 spark plugs except worse-it bogs and loads up and sounds like I have a flat tire! But I can drop it in 2nd(automatic) and get it in higher rpms for a few seconds and it clears up. I can but it back in drive and most of the time it clears it up and drives fine. Then the next time I crank it up sometimes it will be better sometime it wont. Each morning though this is the case. Through this whole ordeal I have been tuning hoping I can fix it. I have tried in speed desnsity and MAF. At times we would flash it and it would be fine then start back up sometimes in minutes other times hours. We thought I may of had a corrupt file but I put my the tune in I had before the headers(that I had no issues with before) and it didnt help. Ive read about you F-bod guys having issues with your o2's heating up after LT's and I dont know if these sound like problems from that. I have a stock MAF but it is descreened(for over year now). COuld this be a factor? The only code Im getting now is a P0200(injector circuit malfunction). Please help Im running out of ideas! My mods in the sig a current! Thanks!
Old Sep 26, 2005 | 07:50 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Could be one of several issues. LT's are known to cause a rich condition at idle, and sometimes lean at cruising. You need to put that puppy on a scanner and see where your LTFT's are.
Another thing to check is all the wiring connections topside. Make sure all the coil/injector harnesses are plugged in right/tight. The P0200 could relate to either one, or a short to ground, from what I understand. Might make sure you're getting the full 5V signal from the pcm.
Old Sep 26, 2005 | 07:56 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Yeah I would just start with checking to make sure everything is plugged in and the plugs and wires are good. Thats if you have not done all that already.
Old Sep 26, 2005 | 08:02 PM
Dustin's Avatar
I think you would get a better response if you posted this is the PCM Diagnostics & Tuning section.
Old Sep 26, 2005 | 09:22 PM
Obviously I had to adjust my LTFT's after the exhaust leak fix,and then after the o2 sensor fix but now they are fine except when it starts to load up/surge(whatever you want to call it) and when that happens it shows that Im running out of gas. So my LTFT's are fine except when it loads up. For a second we thought I was running out of injector but it doesnt match up. Ill post this in the PCm section too! Thanks!
