Idle question
If it stays at 1300 even after driving and coming to another stop, then there is an issue. Most idle hang issues on stock cars are caused by either a vacuum leak of some sort, an IAC valve issue, or throttle linkage binding. If the car is throwing a code, scan it and start there. Also, if you have access to a scanner you can check fuel trims as well to help identify a vacuum leak and possibily point you towards areas to inspect depending on what the trims show. You can also scan the TPS voltage and TPS angle percentage to point you towards any possibile linkage binding.
If not, then I'd pull the IAC valve and clean the pintle and the bore, also check the throttle cable for smooth operation and that it fully releases/allows the TB blade to close fully. And finally check for vacuum leaks in/around the TB/bellow/MAF, intake, EGR-to-intake tube, PCV system, etc.
Hope that helps.
Edit: Just noticed that you list "MAF" as a mod. Ported stock MAFs have been known to lead to idle issues for quite a few people. Maybe try a 100% stock MAF and see if the issue goes away.
Lots of things can cause intermittent idle issues, I've spent MANY hours hunting these issues down on some of my own cars, including my '98 LS1. I had an extremely intermittent idle hang on my Z28 this spring, after trying/checking/scaning/replacing almost everything I could think of, it ended up being the EGR valve in the early stages of failure. The valve wasn't bad enough to set a code, but I did get a high idle DTC once. Not saying that the EGR is your issue, could be a dozen other things, but in my case that was the final part that I replaced and that's what did the trick. It's always the last thing you try, aint it?
Sorry about that. For some reason I though you listed an '00 car in your sig. My mistake.....
