Tach Signal for shift lite?
Old Sep 30, 2005 | 11:58 PM
Notime383's Avatar
Default Tach Signal for shift lite?
Where do I get the signal (of ecm or coils) to hook up my shift lite on my 01 Z28? I have autometer lite with module!
Old Oct 1, 2005 | 07:46 AM
Notime383's Avatar
Anyone?
Old Oct 1, 2005 | 11:32 AM
White.Lightning's Avatar
Dont quote me but try this....
In the engine bay, passenger side, there is a red connector (furthest from the fednerwell). Connect into pin #10 which is typically a white wire.
This is a common hook up for tach signals. HTH.
Andy
Old Oct 1, 2005 | 02:01 PM
flash12t's Avatar
1999, 2000, 2001, or 2002 model F-Body you will need to pop the gray case off of the lower part of the PCM
should locate the number ten (10) pin The wire should be white in color.
Old Oct 1, 2005 | 02:05 PM
ss1129's Avatar
http://www.installuniversity.com/ins...sity/index.htm
Old Oct 1, 2005 | 10:03 PM
Notime383's Avatar
Thanks for the info guys!
