ideling problems?
Old Oct 1, 2005 | 11:37 PM
sscamaroburn02's Avatar
Default ideling problems?
I went to start up my car today and it started up but it was trying to idle at like 300 rpms. i had to give it gas to bring the rpms up and after it kinda warmed up the ideling was good. When i went to turn the air on the rpms kinda dropped again.. What is causing this? Is it something that i should replace now. I heard it could be my O2 sensors going bad, is this true?????
Old Oct 1, 2005 | 11:38 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Tons of things can cause idling issues. Hard to say what it is unless you're getting a code to point you in the right direction.
Best thing is to do a search in this section, plus the external engine section and the PCM/diagnostics section under "idle" and you'll get tons of info and ideas to try.
