checking for vacuum leak????
Old Oct 5, 2005 | 01:41 PM
shouldaboughttheZ's Avatar
Default checking for vacuum leak????
How do I check for a vacuum leak? For some reason soap and water in a spray bottle comes to mind.
Anyone got any tips?
Old Oct 5, 2005 | 02:52 PM
dlmater's Avatar
Soapy water is usually used to test for a pressure leak. As the pressure is relieved at the leak, the solution bubbles.
Back in the "old days" would use a can of ether and spray around the intake/carb base. When the engine RPM's increased, there was the leak. However, I am not sure this is the best way to do it now. I am sure others here may have a better way.
Old Oct 6, 2005 | 08:04 AM
I read that I could use TB cleaner and spray around the hoses and intake? That if there was a leak that the motor would suck in the vapors and the engine would idle smooth for a second or two.
Also found the soap and water trick works on what you said above.
Old Oct 7, 2005 | 12:45 AM
luv2spd's Avatar
Carb cleaner!
Old Oct 7, 2005 | 01:03 AM
SSDriver's Avatar
don't forget there are a few hoses connected on the back of the intake (AIR, and Brake Booster).
Old Oct 7, 2005 | 08:03 AM
Was going to check into it this weekend.
Carb cleaner, got it.
