Stock manifold bolts to ARP header studs
1. When I put the studs in, what should I apply to the threads? I was thinking ARP moly lube, anti-seize, or thread locker (like on the stock manifold bolts).
2. When I install the studs, how tight do the actual studs themselves get tightened to?
3. When I tighten the nuts, should I just follow the procedure for the stock manifold bolts - 11 lb ft first pass, inside out, then 18 lb ft final pass, inside out?
Thank you for your help,
Chris
