Exhaust Help!!!!!!!!!
Old Oct 10, 2005 | 06:00 PM
CamaroRumble's Avatar
Default Exhaust Help!!!!!!!!!
I have a 98 z28 and im going to put pacesetter lts and summit x pipe on there but i need to know what type of muffler to use! Please help me!
Old Oct 10, 2005 | 06:07 PM
Speed Density's Avatar
hashtagBMW
Loud..........Sweet Thunders.............Mild..........bullets........ .Quite........Xr1s. Thats all idle noise they all sound off the hook at WOT, im gettin the same setup and im getting xr1s.
Old Oct 10, 2005 | 06:09 PM
thanks...ive heard good things about sweet thunder but i still want more advice so continue to post please!
Old Oct 10, 2005 | 06:12 PM
hashtagBMW
there a chamberd muffler, its just like a glass pack for trucks. If you like everything to rattle in your car and for heads to turn everywere, thats what i like, ne way go with them, and the clearance is just like a pipe it doesent get bigger like a traditonal round muffler, but if you know your going to get in **** for having your car really loud the you should run with some xr1s cuz if there is a cop beihind you, then you can drive off safley and not get pulld over for noise.
Old Oct 10, 2005 | 06:19 PM
whats an xr1? also there are so many lengths gauges diameters of sweet thunders so help me there
Old Oct 10, 2005 | 06:33 PM
bump but whats and xr1?
Old Oct 10, 2005 | 07:03 PM
hashtagBMW
Get the 18in sweet thunders, and Xr1 is a racing muffler that borla makes, there some of the best out there. There not a norlmal muffler, like an oval there round just for setups like true duals. And did you get new plugs for your Lts, its good to change em while you do the LTs, unless you have newer plugs.
Old Oct 10, 2005 | 07:07 PM
spark plugs?
 Michael S. Palmer
Old Oct 10, 2005 | 07:14 PM
hashtagBMW
K if you have ever lookd at you stock exhuast manifolds or spark plugs and wires, your going to know its going to be a bitch to put LTs on then a couple months later have to put new plugs in there. I am gettin new plugs and wires for my car so i can do it all at once, and make sure if you consider doing plugs and wires, get OTVC (over the valve cover) cuz your headers will touch your plugs and thats not good at all cuz your wires willmelt.
Old Oct 10, 2005 | 08:20 PM
bigradical's Avatar
It's definitely a good idea to change the plugs and wires while you do a header install. It'll be the easiest plug change you ever do, lol.
Old Oct 11, 2005 | 09:31 AM
Raise's Avatar
i kinda like the way the flowmaster 1 chambered mufflers sound with true duals. check out ls1sounds.com under the true duals section. they have atleast 2-3 different clips of the 1-chambered flowmaster mufflers. they arent as loud and mean as the sweet thunders, but they are very refined sounding.....with a nice old-school muscle car tone check it out
Old Oct 11, 2005 | 11:46 AM
LS69TA's Avatar
Old Oct 11, 2005 | 03:17 PM
JBIRD02's Avatar
Originally Posted by LS69TA
1-chambers!
Old Oct 11, 2005 | 09:09 PM
I did read a whole post about "slowmasters" they got an *** kickin from alot of ls1tech members that absolutely hated them...dont think i will be putting "slowmasters" on my car!
Old Oct 11, 2005 | 09:44 PM
LS69TA's Avatar
Yea, the 80 series factory replacement sucks. The 1 chambers dont. They're called race mufflers for a reason.
