best wire/plug combo for nitrous use
Old Oct 10, 2005 | 10:13 PM
z28pat's Avatar
Default best wire/plug combo for nitrous use
I am currently spraying a 100 wet shot, occasionally,
and I changed the plugs NGk Tr6s for safety,
so should I get new wires and which ones?
thanks
pat
Old Oct 11, 2005 | 08:03 AM
Order 66's Avatar
MSD wires are good.
Old Oct 11, 2005 | 08:06 AM
35thls1ss19's Avatar
MSD's here too
Old Oct 11, 2005 | 08:43 AM
chris2000ss's Avatar
MSD wires and tr-6 plugs
Old Oct 11, 2005 | 08:49 AM
SSDriver's Avatar
I was running the MSD wires but they were always a pain to tell if there are clicked on or not. My car on the scanner kept showing I was having random misfires on a few cylinders. I damaged one of my wires(not sure how), the connector that clicks on the plug broke in half(the wire was NOT ripped out of the connector, but the connector actually broke in half) and part of it was stuck on the plug. I just switched over to Taylor wires and couldn't be more happy. You can actually feel when the wires clicks on(very clear and concise when it clicks) and they go on/off much easier. I no longer have the random misfires on different cylinders. Not positive the misfires were related to the wires but thats all that changed and there gone now. I use TR6 plugs as well and never had a problem with them.
EDIT: I had no clue that I was having misfires, the engine seemed to run great. The misfires only showed up on the scanner(in datastream mode) and never threw a code. They would only happen when I was at WOT/reving the motor and it would switch between cylinders.
-William
Old Oct 11, 2005 | 11:19 AM
nostyta's Avatar
I'm running the MSD wires and TR6 plugs.
Old Oct 11, 2005 | 06:57 PM
z28pat's Avatar
cool,
stupid question,
does MSD only make one kind of plug wire for the ls1's
pat
Old Oct 11, 2005 | 08:11 PM
nostyta's Avatar
The MSD 8.5 mm super conductors are the only ones that I've seen.
Old Oct 12, 2005 | 12:05 AM
01 LS1 SS's Avatar
maybe i can squeeze a few ?'s regarding plugs. I have a close to stock SS. What do you guys think about Taylor 9mm Plug wires? are they worth getting? & how much do they run for?
Old Oct 12, 2005 | 02:59 PM
CamaroSS01SLP's Avatar
-William
There's so many different types of Taylor wires over on the Thunder Racing website so.....Which ones do you get/have?.....
Old Oct 12, 2005 | 06:24 PM
FloridaZ's Avatar
Thumbs up
Thundervolts and Tr6's here.
Old Oct 12, 2005 | 06:28 PM
davered00ss's Avatar
Moderator
MDS wires and NGK tr6 plugs.
