LT and ORY install gone wrong???
Old Oct 13, 2005 | 02:44 PM
Brian2006's Avatar
Default LT and ORY install gone wrong???
Well I finally got my pacesetter LTs and TSP ORY installed and the car is running really eratic. Only when the engine is warm, will the car shake and not accelerate smoothly when gettin on the gas.
Now the 02 sims are not in yet but I was told that these she not affect the car to the point where it jumps/shakes when giving some gas.
Any ideas? Or is it the 02 sims causing this mess.
Old Oct 14, 2005 | 09:54 PM
WILWAXU's Avatar
Do you have the front O2's hooked up?
Old Oct 14, 2005 | 09:57 PM
mcamp001's Avatar
check plugs/wires
Old Oct 14, 2005 | 10:23 PM
Full-Force's Avatar
Most common problem after putting headers on is one of the o2 harnesses touching the header. It will burn through and usually pop a fuse.
Check your fuses. I replaced a fuse on a guys car one time that had headers installed on it by someone else. I think the fuse was labeled eng sensor, or sensor something. It was popped.
