post pics of you duals over the axle
I had to grind off some of the upper panhard bar on the driver's side to get some clearance for the pipe, but it is was easy. You can use you stock intermediate pipe as-is to get over one size, and two standard dynomax (check their site) 2.5" elbows on the drivers side. You just slip one into the other and twist the joint to get the right angle.
