Need help with tach install
Old Oct 15, 2005 | 04:29 PM
01ls1lover's Avatar
Default Need help with tach install
Car is a 2001 WS6 need instructions for all wiring and pix if possible any help is appreciated thanx in advance...
Old Oct 15, 2005 | 06:06 PM
01ls1lover's Avatar
Hmm anyone..? and its an auto meter.. ive been to the site but im having trouble finding out were to tap into the ignition....? the green wire on the tach.And does anyone have a wireing diagram? or know were i could get one...
Old Oct 15, 2005 | 06:07 PM
davered00ss's Avatar
Moderator
You plug it into the tach signal on your pcm.
Old Oct 15, 2005 | 06:24 PM
01ls1lover's Avatar
I have no idea were that is.. i need a wire diagram for this frickin thing anyone know were to get one befor ei **** somehting up..
Old Oct 15, 2005 | 06:31 PM
Moderator
PCM is on the firewall on the passenger side of the engine bay. The tach signal is the no.10 pin. You can check out some info on installuniversity.com.
Moderator
No 10 pin is a white wire.
