Removing O2 on Hookers?
Old Oct 15, 2005 | 06:59 PM
ChicagoTransAm's Avatar
Default Removing O2 on Hookers?
I have a feeling that my O2 sensor is rubbing the underside of the car. OK, it's more of a certainty. The black sheeth is completly worn away. What's going on here? I can't get it out more than 2 turns without it hitting the bottom of the car and it's shorting out causing my ECM Sensor fuse to blow. (No reverse, MAF etc) UGH!
Old Oct 15, 2005 | 08:25 PM
01TAFlyer's Avatar
Don't remove your o2 sensor if it is the front sensor. Rubbing the underside doesn't really sound like a problem, the black sheath probably melted away due to the header. Just rewrap your cable with some heat wrap and zip tie it away.
Old Oct 15, 2005 | 08:45 PM
OK, it's not due to heat. It's due to it rubbing up against the underside of the car. The car actually has DENTS from the O2 smacking into it. Can someone with Hooker LTs take a look at theirs driver side and tell me how much clearence they have between the header and the heat shield?
Old Oct 17, 2005 | 12:55 AM
bump?
Old Oct 17, 2005 | 11:22 AM
WhiteRhino's Avatar
Mine was hitting the heat shield.I cut out the part of the heat shield it was hitting and its been fine for over 3 yrs.
Old Oct 17, 2005 | 02:48 PM
So how the heck do you get the O2 sensor out to change it? Evidently mine is shorting out on the heat shield. I'm hoping this is the cause of my upper RPM misfire as well....
Old Oct 17, 2005 | 03:07 PM
WhiteRhino's Avatar
Mine shorted out as well,on the heat shield.With the wire unplugged,I just used an open ended wrench to break it loose and then spun it out with my fingers.Every so often I would spin the wire so it wouldn't get bunched up.It came out quite easily.
You may have to try and cut some of the heatshield out before you remove it.You should be able to cut 2 slits in the shield on each side of the censor and bend it out of the way.
Old Oct 18, 2005 | 03:24 AM
Thanks guys...I cut away the heat shield and was able to remove it. However, it seems that it is pretty tight up against the fuel/brake lines still. I got stuck buying a Bosch till tomorrow when I'll grab an AC Delco. Ya happen to know if the Delcos are shorter at all?
FWIW, no more stutter at high RPMs. Hell...I scared my best friend while on the on ramp New Goodyear GS D3 285s still let the car go sideways half way through 3rd....
 Michael S. Palmer
Old Oct 18, 2005 | 10:48 AM
s.o.m.SS's Avatar
ive got hooker LT's and i took my 02 out last night to check it cuz i scanned my comp and its throwing all the driver side codes... it was a bitch putting it back it, but it helped a lot by jacking the front end up
Old Oct 18, 2005 | 11:53 AM
WhiteRhino's Avatar
Mines pretty close to the lines as well.But not close enough to worry about.I'm not sure if the o2's are shorter.I think they are all the same.I've been running the Vette rear o2's for awhile.
