coolant tubes & oil sending unit...
Old Oct 16, 2005 | 05:59 PM
slimcracka's Avatar
Default coolant tubes & oil sending unit...
ok im in the process of doin a ls6 intake swap..and im bout to put the coolant tubes on but the hole in the head keeps leaking coolant and it keeps getting in the threads of the head for the bolt...i tryed to clean it out but as soon as i get it cleaned it gets full again....will it hurt anything to install the plugs and tubes with coolant in the bolt hole...and when i tighten the bolt up will it trap coolant in there and cause it to crack my head when it gets up to temp..? thanx just tryin to be cautios .... and is there any special tool to get the oil sending unit off? thanx
justin
Old Oct 16, 2005 | 08:41 PM
LS1-450's Avatar
Don't tighten those bolts with coolant in the holes. Drain the coolant if it keeps happening & then re-fill the system after finishing. Can't remember the oil sending unit size, but, a long socket will do the job (Am thining 1-1/4" long exptension, but, check 'cuz I am not sure). Call your local GM parts department & they will know the proper size & length for sure.
Old Oct 16, 2005 | 09:51 PM
slimcracka's Avatar
so i need to make sure there is no coolant in the threads........thanx are you sure when i tighten down the bolt it wont come out...thanx
