02 sensor threw a code, serious?
Old Oct 20, 2005 | 08:43 PM
Vax's Avatar
Vax
Default 02 sensor threw a code, serious?
Threw a code showing an o2 heater undervolt?
is this serious? (I'll get the exact code I ahve it written down)
my mechanic said it just needs the connector respliced or something similar..
Old Oct 21, 2005 | 12:00 AM
Bad Blu Formula's Avatar
Its nothing. They just get lazy over time. Just disconnect your battery for about 20-30 minutes and the code will be cleared.
Old Oct 21, 2005 | 01:08 AM
Vax's Avatar
Vax
no no, it keeps throwing it, I tried resetting it and all.
I just need to know what to do to fix it, was my mechanic right?
Old Oct 21, 2005 | 10:45 AM
Badls6SS's Avatar
NOTING NEEDS TO BE RESPLICED IT SOUNDS LIKE YOU NEED A NEW O2 SENSOR. iF THERE PRE CAT I WOULD REPLACE BOTH SAME AGE AND MILEAGE!
Old Oct 21, 2005 | 11:11 AM
Toasty's Avatar
heh....Caps Lock is a bitch. Check what code it is- if its the rears, not a big deal, but if its the fronts it may be causing internal issues. I just replaced my rear drivers O2 this week...its a PITA to break loose from all the rust.
