getting wires through the firewall
Old Oct 23, 2005 | 08:21 PM
bigti99a's Avatar
Default getting wires through the firewall
ok i have been putting off an a pillar install. i have everything i need, whats the best way to run the sending wires to the engine bay? any help or insight would be sweet!
Old Oct 23, 2005 | 08:26 PM
The PAT WS6's Avatar
passenger side, pull of the piece that runs along the bottom of door and pull the carpet back. then get under the hood and remove the comp. you will see a ruber gromet pull it out, and that should be your easiest way
Old Oct 23, 2005 | 08:30 PM
black00TA's Avatar
depends where your wires gotta go, if your doing the a/f gauge run it up through your shifter into the car.
or what i did was run it through drivers side at the steering shaft, drill small hole and use rubber grommet.
