Intake problem
Old Oct 26, 2005 | 08:48 PM
Nearly_Gone's Avatar
Question Intake problem
i am at the end of my patience. maybe one of you has the answer.
i just put a BBK SSI intake manifold on my car and now it wont stay running. i broke the oil pressure sender on it and replaced it. the car turns over, rev a little high and sputters to a stop. with the sender broken, the gauge read 0, now it is pegged out. if i play with the throttle, it will stay running and gain RPM's with no problem. but when i let it out, it feels like the computer is killing cylinders to shut it down. when i unplug the MAFs, it will stay on but with a high idle. as soon as i plug it in, it dies. i know everything is hookep up right and plugged in. and the Service Engine light is NOT on.
anyone have any ideas? any help would be great. thanks guys
Old Oct 27, 2005 | 08:33 AM
thunderstruck's Avatar
all i can suggest is double check everything. sounds like its an air leak. im not real familiar with the bbk intake, but does it use the stock coolant crossover pipes? maybe the intake isnt fully seated
Old Oct 27, 2005 | 08:39 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Was the intake new/used?
You check your o2 sensors? (Sometimes they seem to have that kind of effect on a motor if damaged or unplugged.)
You have EGR or AIR removed/still installed?
I am also not familiar with that particular intake, so it is hard to say if it is the intake that is causing the problems.
Old Oct 27, 2005 | 09:19 AM
technical's Avatar
Air leak is causing the high idle(!maf) and stalling.
You might have pinched a wire on the harness near the oil pressure sender.
I suspect since the intake is Al it is much easier to short a wire if you catch it.
Old Oct 27, 2005 | 10:59 PM
its a new intake. i will check all of the wires and hoses. the air system and EGR is still on. thanks guys
Old Oct 27, 2005 | 11:02 PM
bmfcamaro's Avatar
fun part. take it back off and double check everything. how is the clearance with the knock sensors.
