plug wires
Old Oct 30, 2005 | 08:11 PM
purple98haz28's Avatar
Default plug wires
i am going to change my plugs next weekend with some tr6's for nitrous and was wondering what i should use for some new plug wires. thanks
Old Oct 30, 2005 | 08:16 PM
SS1875's Avatar
I have used both the MSD and Taylor Thundervolt (currently running Thundervolt ) wires but have heard that the Moroso wires are good also.
Old Oct 30, 2005 | 09:48 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
I run Taylor Thundervolts. They are the most expensive wire pretty much, around $60 bucks or more I think. They have such low resistance, its rediculous. So low in fact, I think I can probably pick them up on the AM radio. I haven't tried it yet though. I forgot what the actual number was when I tested them.
They are the best quality wire IMO. I run long tubes, and up until recently, ran without the heat protectors. There wasn't a hint of any damage on any of the wires, and they were probably on there for a good 15k miles. I got the boots for free though, so I figured why not throw them on.
Old Oct 30, 2005 | 10:36 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Stockers are fine.
I went with some MSD's myself though, this was before I knew that the stock ones hold up good.
Old Oct 31, 2005 | 09:11 PM
well my stockers have 94 k on them so do i need to replace them with the plugs ore should they be fine... if i ohm them out what should resistance be
Old Oct 31, 2005 | 09:45 PM
RedRider81's Avatar
MSD wires both look and work great .
Old Oct 31, 2005 | 09:54 PM
LS1-450's Avatar
Replace them. Include the Magnecore website as part of your plug wire research. You will find some interesting information there. Good-luck.
Old Oct 31, 2005 | 10:18 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Stock has always worked fine for me, on both my stock/bolt-on and modified LS1s.
 Michael S. Palmer
Old Oct 31, 2005 | 10:23 PM
OneMeanZ's Avatar
Are stockers cheaper than the aftermarket??
Old Oct 31, 2005 | 10:49 PM
black00TA's Avatar
im using the MSD8.5 now and they are noticably smoother at low RPM's than the stockers.
my vote for the MSD. though i have not tried taylor or moroso.
Old Nov 1, 2005 | 05:38 AM
where do i get the boots and i just cut the wires to the exact same length that i take off right? sorry for any newbish questions
Old Nov 1, 2005 | 09:17 AM
LS69TA's Avatar
I got my MSD's from Thunder --->. They look pretty good too.
Old Nov 1, 2005 | 12:26 PM
nostyta's Avatar
MSDs here, had them on the car for about three years with no problems.
