Lid, Cold Air Intake, Ram Air ?
It seems to me from what I have read that a lid is basically a direct replacement for the stock air filter. They aren't that much different in design or appearence except for the increase in air flow. But if you get a Cold Air system, the air filter is moved to the bottom of the engine bay so there is no use or possibility of having a lid right? I have a 2000 SS, so if there was a CAI on that would that render the hood scoop useless or is it already useless?
I'm just a little confused on the subject. Overall the question is what I would want to do with my SS in regards to the air intake? I want to get my options in order. Thanks!
The CAI is simply ductwork that directs the air into the filter, you can get that seperately as well.
You can also do the free ram air mod (cut the bottom out of the place the air filter sits) you can combine any of these mods with each other, or do them seperately.
As for the usefulness of the SS scoop, you'll have to get an SS owner to respond
I'd be a little cautious about the ram air ducting as there have been cases of engines getting hydo locked, not many, but enough to make it a slight concern depending on how much rain you get, and if the car is a daily driver or not
