Quick Y-pipe ?
Old Nov 1, 2005 | 10:39 PM
2002RamAir's Avatar
Default Quick Y-pipe ?
Hello all,
I currently have a QTP y-pipe and cant stand how it looks and how low it hangs. It has got to be one of the biggest pieces of ****. Anyways, I want to replace it. What is about the best y-pipe fitment wise? I am currently running QTP long tubes and a corsa catback.
Thx
Old Nov 1, 2005 | 10:56 PM
Full-Force's Avatar
Well as far as one that will bolt up to your headers and bolt up to your catback with no modification at all you might have the only one that will do that.
If you want the tightest fitting y pipe that has max ground clearance then its the Pacesetter hands down due to the frame clearance areas on it. The only negative thing about the Pacesetter is the extra material left inside the merge. I just put mine up for sale a few minutes ago in the for sale section. I have fixed the merge. I used my die grinder and burnt up about 3 stones porting the merge out. It goes a long way to reduce rasp and increase flow.
