might sound stupid!!
Old Nov 11, 2005 | 07:58 PM
Tranzaman00's Avatar
Default might sound stupid!!
Ok so most have done the tb bypass mod. could you run a tee in the low pressure line of the ac and hook to the TB were the coolant ran through and then loop back into the ac line from the other nipple coming off the ac? Thought this might cool the TB?
Old Nov 11, 2005 | 08:32 PM
TA TECH's Avatar
lol! I can rig anything up butt that would be a waste of time and some tore up AC lines!
Old Nov 11, 2005 | 08:35 PM
right on, I thought it might chill the TB when the ac was on. Thats all. Seems like you could run some c02 or something through it?
Old Nov 11, 2005 | 08:51 PM
TA TECH's Avatar
It really doesn't get all that hot if coolant isn't running threw it unless ya heat soak it sitting still idling, be better to just ice the intake down on a few runs!theres not much volume actually in the trottlebody passage to even really help it would heat back up soon as it left the trottle body!If ya runn at a strip any ya could se if ya got any time improvements if ya iced it a time or two!Me I just let it cool down enough that I can touch the header and hoop in and go down the track!
